Home > 130 > Need help with measures rear crossmember
Defendertomten
Sweden 2000 Defender 130 Td5 HCPU Coniston Green
Got somewhat stuck with the project
change rear crossmember.
Anyone who hawe some diagram over measurements?
I lost mine after I cut it.
It's rear crossmember only with
Short extensions, not chassi extension. Land Rover owner since 2003
2008 Disco3 manual
2000 Defender 130 td5 snorkel warn m6000
Post #1075989 23rd Sep 2025 4:22pm
Dinnu
This is for a 130?
What most people do is leave the tub in place, offer in the new crossmember, aligning all bolt holes, and weld in place.
I only replaced once a crossmember, and what I am sure about is that the crossmember face should be perfectly perpendicular with the tub supports. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1076032 24th Sep 2025 4:56am
Defendertomten
Yes, but I had a big box instead of tub. So I removed that.
I have a tub too but I thought that i would get by the moment with lifting the tub on of for measuring. Land Rover owner since 2003
2008 Disco3 manual
Post #1076061 24th Sep 2025 11:39am
jst
I'll measure mine later Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1076065 24th Sep 2025 12:50pm
Dinnu
As far as I know, the 130 used to be a stretched 110 until Landrover made a dedicated chassis. So probably drawings for rear section of a 110 will be good. Should be plenty drawings online. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1076070 24th Sep 2025 2:09pm
jst
835mm from rear of rear spring hanger in location shown
to outside flat edge of x member.
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1076077 24th Sep 2025 3:14pm
Defendertomten
Thanks😁 Land Rover owner since 2003
2008 Disco3 manual
Post #1076118 24th Sep 2025 10:50pm
