![]() | Home > 130 > Need help with measures rear crossmember |
Defendertomten Member Since: 19 Aug 2020 Location: Avesta Posts: 56 ![]() ![]() ![]() |
Got somewhat stuck with the project
change rear crossmember. Anyone who hawe some diagram over measurements? I lost mine after I cut it. It's rear crossmember only with Short extensions, not chassi extension. Land Rover owner since 2003 2008 Disco3 manual 2000 Defender 130 td5 snorkel warn m6000 |
Yes, but I had a big box instead of tub. So I removed that.
I have a tub too but I thought that i would get by the moment with lifting the tub on of for measuring. Land Rover owner since 2003 2008 Disco3 manual 2000 Defender 130 td5 snorkel warn m6000 |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8448 ![]() ![]() ![]() |
I'll measure mine later Cheers
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3634 ![]() ![]() ![]() |
As far as I know, the 130 used to be a stretched 110 until Landrover made a dedicated chassis. So probably drawings for rear section of a 110 will be good. Should be plenty drawings online. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
835mm from rear of rear spring hanger in location shown
![]() Click image to enlarge to outside flat edge of x member. ![]() Click image to enlarge Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Thanks😁 Land Rover owner since 2003
