Home > Td5 > TD5 Locking and Double Horn Sound
Tank
Scotland 2004 Defender 90 Td5 HT Zermatt Silver
So, the Landy has started sounding the horn twice when I lock it.
I know this means the Landy thinks there is an issue with a door or the rear door not locking or latching, but they all seem ok. I have changed all three door switches and it still does it.
What else can I look at ?
Any ideas?
Post #1075664 18th Sep 2025 10:31am
rustandoil
Bonnet switch?
Post #1075665 18th Sep 2025 10:45am
Martin
Site Admin
Don't forget the bonnet switch too!
Edit: too slow Laughing  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1075666 18th Sep 2025 10:45am
4RF RDS
Re: TD5 Locking and Double Horn Sound
Any ideas?
As posted a double beep of the horn means that a door is not identified as closed by the 10AS unit. It is most likely the bonnet switch. Bend it up a tad Thumbs Up
Good luck. 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #1075940 22nd Sep 2025 8:10pm
Tank
Thanks for the replies. Been away, hence the delay replying Smile
Bonnect switch is ok, I think, and I replaced the other three switches.
What else can it be?
Would plugging in the Nannocom tell me anything?
Post #1076619 1st Oct 2025 10:44am
4RF RDS
Nanocom can tell you which switches are actually working and or open. 2020 range Rover Mk IV Autobiography PHEV
1967 MGB GT
Post #1076627 1st Oct 2025 1:00pm
markb110
For two two years the rubber boot on my bonnet switch was torn, but no issues.
Then a few months back the alarm would just go off, once three hours after I locked it, then thirty seconds, then an hour, then about an hour after that, so I then put it in the garage and left it unlocked.
I checked all the door switches then decided to replace the bonnet switch and no issues since.
For the cost, and because it looks ok, it still might be worth changing it.
Good luck
Post #1076632 1st Oct 2025 2:37pm
landy andy
Yes plugging in your Nano will tell you which switches are doing what. Or the other way of doing it it to see which of your doors does not trigger the interior light. Often it is the rear door (boot).
Post #1076648 1st Oct 2025 4:58pm
Tank
Thank you.
Will try out all these things
Post #1076650 1st Oct 2025 5:07pm
Tank
Ok what does this all mean.
What's the fault?
Post #1076663 1st Oct 2025 6:49pm
landy andy
When you got those results were ALL your doors shut?
It tells me that it thinks passenger door is open and unlocked and drivers door is unlocked.
Sit in, and lock all doors. Then what you get.
Post #1076669 1st Oct 2025 8:11pm
Tank
OK, Nanocom photos when I'm in the car and doors locked.
When I leave the doors locked and start the car the alarm wails than honking Smile
Post #1076727 2nd Oct 2025 2:29pm
landy andy
Just checked a few things for you.
The Nanocom does NOT KNOW which door is open and which door is shut.
It knows the drivers door
The bonnet
BUT. It then groups passenger doors, and boot all together.
Post #1076728 2nd Oct 2025 2:49pm
landy andy
Post #1076731 2nd Oct 2025 3:10pm
landy andy
First pic is all doors closed and locked
Second pic is all doors closed but unlocked
Third pic is passenger only open, and all doors unlocked
Fourth pic is boot door only open, and all doors unlocked
Post #1076732 2nd Oct 2025 3:13pm
