Home > Maintenance & Modifications > 90 td5/tdci mid pipe exhaust fit
jst
Afternoon,
Just after a litte help please.
I'm looking to fit a tdci mid pipe with silencer under my Vehicle, currently has a tdci straight through pipe fitted.
could someone please take a photo and show me where the 2 exhaust hangers go on the chassis?
Current chassis end brackets have been modified for the straight through pipe and if they are used the a frame hits the rear exhaust bracket of the new mid box on full droop.
A frame contacts top of that rear bracket and pushes exhaust down stretching the rubber mount. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1075442 15th Sep 2025 1:52pm
Retroanaconda
Front one is just aft of the transfer box on the LH chassis rail. Rear one mounts on the A-frame crossmember.
Tdci has a different position rear mount to Td5 as the centre box is positioned further aft on the pipe to clear the handbrake drum (as LT230 is further aft in a Tdci than in a Td5).
All the Tdci vehicles I have seen have had the rear mount welded onto crossmember whereas Td5 ones are bolted.
Front mount here:
Rear mount (Td5 type shown):
Difference in boxes showing differing rear mount position (Td5 top, Tdci bottom):
Post #1075465 15th Sep 2025 6:45pm
jst
That's great, thank you.
Front is same.
Rear on mine seems to be further back, td5 mid pipe, plus the hanger comes off the back of the silencer rim as opposed to the pipework behind the silencer as your picture shows.
Whole lot on mine seems further back though.
Maybe I need a new mount on the pipe rather than the box. Will do some measuring. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1075491 15th Sep 2025 11:11pm
