![]() | Home > Maintenance & Modifications > 90 td5/tdci mid pipe exhaust fit |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2769 ![]() ![]() |
Front one is just aft of the transfer box on the LH chassis rail. Rear one mounts on the A-frame crossmember.
Tdci has a different position rear mount to Td5 as the centre box is positioned further aft on the pipe to clear the handbrake drum (as LT230 is further aft in a Tdci than in a Td5). All the Tdci vehicles I have seen have had the rear mount welded onto crossmember whereas Td5 ones are bolted. Front mount here: ![]() Click image to enlarge Rear mount (Td5 type shown): ![]() Click image to enlarge Difference in boxes showing differing rear mount position (Td5 top, Tdci bottom): ![]() Click image to enlarge |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8408 ![]() ![]() ![]() |
That's great, thank you.
Front is same. Rear on mine seems to be further back, td5 mid pipe, plus the hanger comes off the back of the silencer rim as opposed to the pipework behind the silencer as your picture shows. Whole lot on mine seems further back though. Maybe I need a new mount on the pipe rather than the box. Will do some measuring. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
