![]() | Home > Tdi > 300tdi Fuel Pump - Any Tuners in Surrey/London/SE England? |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 881 ![]() ![]() ![]() |
Did they say what the problem with the fuel pump was? You don't really touch the pump or fueling settings when changing a TDI timing belt so I wonder just what has happened here?
James130 Member Since: 14 Mar 2015 Location: UK Posts: 7 ![]() ![]() |
Hi
He said when the old timing belt was removed, the pump 'jumped' inside. Whilst going OK now (once warmed up) after a pump specialist attended, it definitely needs a retune, as it is not as it was before. I've tried numerous web searches, but it's all ECU remappers these days... Any hints to who might still have that pump tune capability would be very grateful received. Many thanks - James. |
'Pump jumped' sounds like they didn't fit the locking/timing pin before removing the belt and the pump moved off it's position due to cam/spring pressure. That shouldn't be a huge issue except sounds like they don't really know what they are doing! This is basic Haynes manual stuff.....
I would get it booked into someone who knows landrovers of that age and ask them to recheck the belt timing. There is no good reason for it to be running any worse after a belt change unless they got something wrong. |
Fossil Member Since: 23 Aug 2015 Location: Bolton Posts: 26 ![]() ![]() ![]() |
It's possible they undid the big nut in the centre of the pump pulley, and the pulley moved relative to the pump. You need a Dti to reset it or check it, but basically you lock the pump in the correct timing position with a lock on the side of the pump. Then set the engine timing and do up the centre nut. Then unlock the pump. Several videos on YouTube on this very subject.
Many thanks for all your replies.
James |
