Home > Tdi > 300tdi Fuel Pump - Any Tuners in Surrey/London/SE England?
James130
Hi All
I have just had a new timing belt fitted to my Defender 300tdi.
Whilst doing so, the mechanic had a problem with the fuel pump.
It’s running again OK now, but I would like to get it properly tuned again, to reduce some smoke.
Does anyone know of any good tuners in the south of England?
Many thanks - James.
Post #1075114 9th Sep 2025 3:29pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Did they say what the problem with the fuel pump was? You don't really touch the pump or fueling settings when changing a TDI timing belt so I wonder just what has happened here?
Post #1075120 9th Sep 2025 4:31pm
James130
Hi
He said when the old timing belt was removed, the pump 'jumped' inside.
Whilst going OK now (once warmed up) after a pump specialist attended, it definitely needs a retune, as it is not as it was before.
I've tried numerous web searches, but it's all ECU remappers these days...
Any hints to who might still have that pump tune capability would be very grateful received.
Post #1075125 9th Sep 2025 5:18pm
I Like Old Skool
'Pump jumped' sounds like they didn't fit the locking/timing pin before removing the belt and the pump moved off it's position due to cam/spring pressure. That shouldn't be a huge issue except sounds like they don't really know what they are doing! This is basic Haynes manual stuff.....
I would get it booked into someone who knows landrovers of that age and ask them to recheck the belt timing. There is no good reason for it to be running any worse after a belt change unless they got something wrong.
Post #1075152 9th Sep 2025 9:16pm
Fossil
United Kingdom 1997 Defender 110 300 Tdi CSW Coniston Green
It's possible they undid the big nut in the centre of the pump pulley, and the pulley moved relative to the pump. You need a Dti to reset it or check it, but basically you lock the pump in the correct timing position with a lock on the side of the pump. Then set the engine timing and do up the centre nut. Then unlock the pump. Several videos on YouTube on this very subject.
Post #1076729 2nd Oct 2025 2:52pm
James130
Many thanks for all your replies.
James
Post #1077225 10th Oct 2025 10:11am
