Home > BMW Engine Conversions > M57 manual in 200tdi
Joeytf
Hello all, looking into putting a m57 in my 200tdi as the title says. My question is, would it fit in the standard lt77 seatbox and gearbox tunnel or would it need to be changed for the r380?
Thanks
Post #1074896 6th Sep 2025 7:25pm
MarkBrown
Wales 1983 Defender 110 Other HT Auto Keswick Green
From what I understand the lt77 isn’t the strongest of gearboxes, so how long it would last behind the m57 I don’t know, I thought the m57 started at around 185hp? That said I had an lt77 behind a 165 hp V8 way back and it was fine. I’d guess that the m57 would make a fair bit more torque than the V8 though. I thought the r380 was a straight swap with the lt77 anyway? Just my thoughts. 1983 110 automatic OM606
Post #1074908 6th Sep 2025 10:15pm
TexasRover
The (removable) tunnel piece and the shape of the seatbox cutout where it connects are different between the LT77 and R380 so they are not a straight swap.
Post #1074918 7th Sep 2025 7:36am
Mo Murphy
If you are using a 6hp auto box then you can use the LT77 era tunnel. I believe (I fitted an auto) the manual BMW gearboxes need more room and require you to use an R380 tunnel.
HTH
50 Shades of Pennine Grey
Post #1074923 7th Sep 2025 8:18am
Joeytf
Thanks Mo, that’s what I was after!
Would you use a defender ratio transfer box or a disco?
Post #1074927 7th Sep 2025 9:55am
Mo Murphy
It depends on which gearbox you are using and whethef or not you are using it for towing.
Post #1074936 7th Sep 2025 12:21pm
jst
From your thread question your fitting m57 to r380? So 185/narrow block?
And want to know if r380 gbox.will fit under lt77 tunnel? No.it won't.
Tbox ratio, depends on final gbox output, tyre size and diff ratios.
For cooling engine likes to be 2k rpm or just above. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1074985 7th Sep 2025 8:24pm
