![]() | Home > General & Technical (L663) > Key not recognized |
| alex68 Member Since: 07 Aug 2025 Location: Steyr Posts: 7
you wrote: "I had to place the key against the steering column to start her." This means the key is still recognized.
I would suggest, as a first step, to replace the battery in the key. If that doesn't help, then I'm afraid that the electronics inside the key got somehow damaged. 25.5MY 110 P300e Carpathian grey |
| Colin68 Member Since: 18 Jul 2024 Location: Blackpool Posts: 128
Yes it picks it up when I put against the Steering column but not when its in my pocket.
| pjeski Member Since: 25 Jul 2023 Location: Michigan Posts: 118
Just happened to mine. Replaced the battery. AOK.
Changed the battery last night but still the same.
| peanutbob Member Since: 12 Feb 2009 Location: UK Posts: 350
What make of battery did you use? It needs to be of the correct power output like Duracell versions .
