Home > General & Technical (L663) > Key not recognized
Colin68
Key not recognized
So I had to use my spare key today. The car is less than 12 months old. The key opened the car but wasn't recognized when when came to start her up. I had to place the key against the steering column to start her. Problem is i kept getting a call from Land Rover to check my car hadn't been stolen. Is there any way to reset the key? Could I delete the key and add again using the Gap IID tool?
Post #1074698 4th Sep 2025 7:16am
alex68
Austria
you wrote: "I had to place the key against the steering column to start her." This means the key is still recognized.
I would suggest, as a first step, to replace the battery in the key. If that doesn't help, then I'm afraid that the electronics inside the key got somehow damaged. 25.5MY 110 P300e Carpathian grey
Post #1074702 4th Sep 2025 8:21am
Colin68
Yes it picks it up when I put against the Steering column but not when its in my pocket.
Post #1074705 4th Sep 2025 8:38am
pjeski
United States
Just happened to mine. Replaced the battery. AOK.
Post #1074745 4th Sep 2025 7:31pm
Colin68
Changed the battery last night but still the same.
Post #1074811 5th Sep 2025 1:09pm
peanutbob
What make of battery did you use? It needs to be of the correct power output like Duracell versions .
Post #1074826 5th Sep 2025 7:07pm
