![]() | Home > General & Technical (L663) > Can anyone explain these settings? |
| lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3528
Nobody?
As l've not altered them l assume they don't apply to my vehicle. l believe that not all the settings apply to the Defender. |
| Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2785
Yes that would be my guess. The CCF is common to many LR vehicles.
Engine power requires re-write of quite a lot of the ECU parameters, definitely can’t just change a single value I’m afraid! |
| Bobbobbobbob Member Since: 04 Jul 2023 Location: Brum Posts: 27
Think about it like this, somewhere there is a setting that changes the picture from a 90 to a 110 on the surround camera but it doesn't add two doors. I'd be really careful about changing settings that haven't been tested. The 4wd, 2wd could be as simple as the graphic in 4x4i or it could affect the stability control.
No l definitely wasn't going to alter any settings l was just interested to know why it was in "2WD" rather than "4WD"
