Home > General & Technical (L663) > Can anyone explain these settings?
lightning
Two settings l found in the CCF. One relates to the 4wd system and appears to be set to "RWD only" l don't know what this means, that the vehicle operates in 2wd until it thinks 4wd is needed?
The other setting relates to engine output, l am sure it can't be as simple as changing the setting to alter the version.
Post #1074520 1st Sep 2025 7:44pm
lightning
Nobody?
As l've not altered them l assume they don't apply to my vehicle. l believe that not all the settings apply to the Defender.
Post #1074596 2nd Sep 2025 5:50pm
Retroanaconda
Yes that would be my guess. The CCF is common to many LR vehicles.
Engine power requires re-write of quite a lot of the ECU parameters, definitely can’t just change a single value I’m afraid!
Post #1074600 2nd Sep 2025 6:38pm
Bobbobbobbob
Think about it like this, somewhere there is a setting that changes the picture from a 90 to a 110 on the surround camera but it doesn't add two doors. I'd be really careful about changing settings that haven't been tested. The 4wd, 2wd could be as simple as the graphic in 4x4i or it could affect the stability control.
Post #1074608 2nd Sep 2025 7:46pm
lightning
No l definitely wasn't going to alter any settings l was just interested to know why it was in "2WD" rather than "4WD"
Post #1074627 3rd Sep 2025 7:46am
