Home > Maintenance & Modifications > Windscreen frame to roof sealant
Bluest
What product is best to use to.seal.this joint? There is some sort of sioicone/RTV/mastic there at the minute that has split. 2007 110 TDCi Station Wagon XS
Post #1074295 29th Aug 2025 8:59am
Co1
If you don’t want to split it completely, I had good results with Captain Tolleys Creeping gap filler. If I remember rightly when I did split the roof, I used the standard sealing strip, but backed up with tiger seal panel bond/sealant.
Post #1074296 29th Aug 2025 9:02am
TexasRover
There is standard foam and rubber seal for that connection.
I find where it get's tricky is in the corners. There is screw that connects the screen to the roof in the corners behind the liner but that works itself loose. It's also a cross head so not that easy to tighten up. I change that screw with a same size hex-head screw and tightened it up with a bunch of locktite, which is not the best application for the type of screw, but so far it has held out (2-years) and the corners are still a tight connection.
Post #1074298 29th Aug 2025 10:11am
