![]() | Home > General & Technical (L663) > Enable swiveling lights on turns? |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2770 ![]() ![]() |
I suspect swivelling lights would require extra hardware as the norm is just up/down as. Iโm not sure if the Defender was ever fitted with it.
I think some higher spec models had the feature where the fog lights are used on turns to illuminate to the side, that could possibly be enabled by CCF edit if fog lights are fitted? |
haymeister Member Since: 24 May 2021 Location: Saitama Posts: 290 ![]() ![]() |
I think what you are referring to when you start up the car and the lights go up and down is the " Automatic Headlight Levelling"
As far as I am aware the Defender does not have the "Dynamic Bend Lighting" or the older "Adaptive Front-lighting System (AFS)" Dynamic Bend Lighting is on the Pixel LED headilghts, and the Defender only has the Matrix LED headlights. However in certain driving modes, when you turn the steering the fog lamps come on in the direction of steering, and when you indicate and turn 22MY Defender 110 D300 S in Pangea Green and Contrast White Roof IG defender_japan "Hulk san" |
sasa Member Since: 05 Mar 2024 Location: ceska lipa Posts: 72 ![]() ![]() |
yes, I confirm, I have fog light illumination after turning the steering wheel. Personally, I don't think it's very good, the turning of the lights, which I had in the Jaguar, was better and more effective. Now it looks like a Hyundai..
alex68 Member Since: 07 Aug 2025 Location: Steyr Posts: 4 ![]() ![]() |
I can also confirm that even with the HSE with Matrix LED, there's no dynamic cornering, but rather just the corresponding fog lightโthat's so old-fashioned.
I've only had mine for 1,000 km and have never driven it in complete darkness, so the high beams have never turned on, so I don't know how it would behave then. But now that autumn is approaching, I'll find out soon enough. 25.5MY 110 P300e Carpathian grey |
CincyRovers1 Member Since: 30 Nov 2023 Location: Cincinnati, Ohio Posts: 136 ![]() ![]() |
All US-spec L663s don't come with the swiveling lights. I don't believe any of the ROW-spec L663s do, either. It just turns on the corresponding fog light during low-speed cornering. None of my LRs - a 2011 LR4 and a 2017 D5 had swiveling dynamic lights. The only thing you get are adaptive leveling headlights on the Premium LEDs and above.
I also like the swiveling lights. PDLS+ on my Macan is an excellent feature, and definelty beneficial. ๐๐๐๐ ๐๐๐๐๐ง๐๐๐ซ ๐๐๐ ๐ ๐๐๐๐ (Pangea Green over Acorn/Lunar) ๐๐๐๐ ๐๐จ๐ซ๐ฌ๐๐ก๐ ๐๐๐๐๐ง ๐ (Dolomite Silver over Black/Bordeaux Red) ๐๐๐๐ ๐๐ข๐ฌ๐๐จ๐ฏ๐๐ซ๐ฒ ๐๐๐ ๐๐ฎ๐ฑ๐ฎ๐ซ๐ฒ ๐๐ข๐ (Aintree Green over Vintage Tan/Ebony) - Gone ๐๐๐๐ ๐๐๐ ๐๐๐ ๐.๐ (Ipanema Sand over Almond/Arabica) - Gone |
