![]() | Home > Puma (Tdci) > Vin plate woes |
110 Iain Member Since: 11 Nov 2019 Location: Scotland Posts: 93 ![]() ![]() ![]() |
Trying to assertain what happens if they agree it's dodgy but can't trace it to anything in particular with it happening years ago is there a process to re register the car .Brain now fried wife stressed to hell about possible loss of car and huge financial hit Endeavour To Persevere
whitepeakwolf Member Since: 03 Feb 2021 Location: Peak District Posts: 49 ![]() ![]() |
You’ll run yourself into a decreasing spiral speculating over the “what ifs ?” - as above, call them is my advice.
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 737 ![]() ![]() ![]() |
If you type “ VIN identification “ into the sites search bar you will find a link which identifies the VIN characters. This gives you certain information about the vehicle as it left the factory ( country, date of manufacture, body type etc).
Hopefully this may help you determine if the vehicle is correct. It may be as simple as a previous owner replacing a VIN plate. Sorry, can’t point you to the specific link, as I have never worked out how to do it. |
Johan_B Member Since: 20 Sep 2024 Location: Gothenburg Posts: 158 ![]() ![]() ![]() |
As a vehicle manufacturer you are obligated to keep record of serial numbers for certain components, typically related to safety or if they are a sizeable part of the vehicle. I’m sure LR can supply you either at least the TC and front and rear axle number. If they check out alright you can probably relax a bit.
In Sweden I doubt we could weld the chassis id onto the frame and if it was possible and done correct there would be an official paper trail with the authorities. |
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 595 ![]() ![]() ![]() |
It looks ok to me, but what do I know. Maybe it needed a new servo and someone scrapped the old one and the plate, maybe not realising it’s needed. Perhaps then a new one was obtained to replace the missing one and hand stamped. I’ve not seen the one in dash but maybe it got corroded and took off because it was loose, even sucked up in the hoover. You can look up the main number, the digits mean different things for example gearbox type, body format engine size etc. From this you can assess whether you’re truck matches the number. Try looking up Land Rover vin decoder. I did this with mine and it all matched. Some of it doesn’t now, but it did when I got it. Mines old, but the axle casings have codes stamped onto them which indicates a time frame in years, as does the transfer box number and gearbox number. Obviously all of these parts could have been replaced at some point. 1983 110 automatic OM606
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5141 ![]() ![]() ![]() |
If anything is wrong with the VIN plate, the examiner will notify you next time you go for an MOT. A few years ago, I failed an MOT because the VIN plate was not riveted in place, just stuck on with double-sided tape after I replaced the brake box. Most MOT examiners are very keen on VIN plates. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
http://www.youtube.com/user/conwy1 |
jbcollier Member Since: 29 Apr 2024 Location: Edmonton AB Posts: 278 ![]() ![]() ![]() |
The VIN is stored inside the ECU. Use a code reader to pull that VIN and see if it matches.
Have scanned ECU vin matches ok got build sheet data looked very carefully and all seems to match it was a poverty spec 110 so no abs/traction , electric windows etc it all seems to match on looking through company that owned it joob sheets it mentions o broken door frame and then repair I know of this repair when I bought I noticed poor welded repair so even old MOT mentions small chip in window drivers side and it's still there. But I can't explain terrible vin plate and plate welded to chassis that has been restamped only thing I can think of is as they had a few landys their workshop did a bit of mixing and matching without any care in providing paperwork and clear details of work done I feel a bit of plonker not noticing
You have a Landy with a repaired/replacement chassis, no big deal. Relax.
Thanks for reply you are probably right I'm probably overthinking it all .anybody out there looking for a good 110 but with a terrible vin plate at a reasonable price appreciate all replies and advice Endeavour To Persevere
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1917 ![]() ![]() |
I think this is pretty likely. These things are pretty fragile in the grand scheme of things - and in a location where they’re liable to catch on clothes etc if you’ve got the bonnet up/off and are leaning into the back of the engine. In my case, mine is almost snapped in two, so I have ‘gaffer taped’ it down. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3490 ![]() ![]() |
How did it go, did you sell it in the end?
Will@LRW Member Since: 04 May 2019 Location: UK Posts: 231 ![]() ![]() ![]() |
DVLA data shows that the keeper changed on 7th September, so probably it's a yes! LR Workshop
New parts illustrations https://www.lrworkshop.com/diagrams/land-r...ed-corners Find a Defender's history and spec: https://defender.lrworkshop.com |
