Home > Puma (Tdci) > Vin plate woes
Page 2 of 2 <12
whitepeakwolf
Give them a call & tell them a potential buyer has voiced their concerns over it’s ID & yes, tell them all that. You’ve nothing to hide after all.
Post #1074237 28th Aug 2025 11:25am
110 Iain
United Kingdom 2008 Defender 110 Puma 2.4 USW Chawton White
Trying to assertain what happens if they agree it's dodgy but can't trace it to anything in particular with it happening years ago is there a process to re register the car .Brain now fried wife stressed to hell about possible loss of car and huge financial hit Endeavour To Persevere
Post #1074238 28th Aug 2025 11:32am
whitepeakwolf
You’ll run yourself into a decreasing spiral speculating over the “what ifs ?” - as above, call them is my advice.
Post #1074239 28th Aug 2025 11:45am
Balvaig
If you type “ VIN identification “ into the sites search bar you will find a link which identifies the VIN characters. This gives you certain information about the vehicle as it left the factory ( country, date of manufacture, body type etc).
Hopefully this may help you determine if the vehicle is correct. It may be as simple as a previous owner replacing a VIN plate.
Sorry, can’t point you to the specific link, as I have never worked out how to do it.
Post #1074240 28th Aug 2025 11:48am
Johan_B
Sweden 2007 Defender 110 Puma 2.4 CSW Tonga Green
As a vehicle manufacturer you are obligated to keep record of serial numbers for certain components, typically related to safety or if they are a sizeable part of the vehicle. I’m sure LR can supply you either at least the TC and front and rear axle number. If they check out alright you can probably relax a bit.
In Sweden I doubt we could weld the chassis id onto the frame and if it was possible and done correct there would be an official paper trail with the authorities.
Post #1074243 28th Aug 2025 12:12pm
MarkBrown
Wales 1983 Defender 110 Other HT Auto Keswick Green
It looks ok to me, but what do I know. Maybe it needed a new servo and someone scrapped the old one and the plate, maybe not realising it’s needed. Perhaps then a new one was obtained to replace the missing one and hand stamped. I’ve not seen the one in dash but maybe it got corroded and took off because it was loose, even sucked up in the hoover. You can look up the main number, the digits mean different things for example gearbox type, body format engine size etc. From this you can assess whether you’re truck matches the number. Try looking up Land Rover vin decoder. I did this with mine and it all matched. Some of it doesn’t now, but it did when I got it. Mines old, but the axle casings have codes stamped onto them which indicates a time frame in years, as does the transfer box number and gearbox number. Obviously all of these parts could have been replaced at some point. 1983 110 automatic OM606
Post #1074244 28th Aug 2025 12:14pm
gilarion
If anything is wrong with the VIN plate, the examiner will notify you next time you go for an MOT. A few years ago, I failed an MOT because the VIN plate was not riveted in place, just stuck on with double-sided tape after I replaced the brake box. Most MOT examiners are very keen on VIN plates. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #1074245 28th Aug 2025 12:41pm
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
The VIN is stored inside the ECU. Use a code reader to pull that VIN and see if it matches.
Post #1074343 30th Aug 2025 12:23am
110 Iain
Have scanned ECU vin matches ok got build sheet data looked very carefully and all seems to match it was a poverty spec 110 so no abs/traction , electric windows etc it all seems to match on looking through company that owned it joob sheets it mentions o broken door frame and then repair I know of this repair when I bought I noticed poor welded repair so even old MOT mentions small chip in window drivers side and it's still there. But I can't explain terrible vin plate and plate welded to chassis that has been restamped only thing I can think of is as they had a few landys their workshop did a bit of mixing and matching without any care in providing paperwork and clear details of work done I feel a bit of plonker not noticing Censored vin plate at the time I thought ok 3 owner and lots of paperwork seemed ok still researching trying to find auction details but no joy yet as it was about 8 years ago have loved this car and want to go to a Landy enthusiast but don't want to pass on anything that is possibly dodgy not sure what to do worried if I contact DVLA it could be stuck on driveway for months while it's investigated and are they gonna find out any more than I have I doubt it Endeavour To Persevere
Post #1074365 30th Aug 2025 2:00pm
jbcollier
You have a Landy with a repaired/replacement chassis, no big deal. Relax.
Post #1074366 30th Aug 2025 2:09pm
110 Iain
Thanks for reply you are probably right I'm probably overthinking it all .anybody out there looking for a good 110 but with a terrible vin plate at a reasonable price appreciate all replies and advice Endeavour To Persevere
Post #1074369 30th Aug 2025 2:21pm
donmacn
I think this is pretty likely. These things are pretty fragile in the grand scheme of things - and in a location where they’re liable to catch on clothes etc if you’ve got the bonnet up/off and are leaning into the back of the engine.
In my case, mine is almost snapped in two, so I have ‘gaffer taped’ it down. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #1074372 30th Aug 2025 4:20pm
lightning
How did it go, did you sell it in the end?
Post #1076175 25th Sep 2025 4:02pm
Will@LRW
 1997 Defender 110 300 Tdi CSW Alpine White
DVLA data shows that the keeper changed on 7th September, so probably it's a yes! LR Workshop
New parts illustrations https://www.lrworkshop.com/diagrams/land-r...ed-corners
Find a Defender's history and spec: https://defender.lrworkshop.com
Post #1076258 26th Sep 2025 8:28pm
Page 2 of 2 <12
