Home > Technical > Fuel Gushing Fuel tank Area 110
London_Landy
United Kingdom 1989 Defender 110 V8 Petrol CSW Indus Silver
Recently when the ignition is on a massive amount of fuel will pour out from the fuel tank, I believe its coming from the top part of the tank, High Pressure hose etc.
the Fuel pump sounds normal. cant start the Motor as it seems fuel is not getting to the engine.
its a 3.5 110 V8 89, I was wondering if you guys think me and my friend (Not mechanically inclined) could drop the tank and replace parts etc, or does this require a mechanic and lift etc.
any advice or diagrams would be helpfull
Post #1074100 26th Aug 2025 3:09pm
jst
Yes. Tank is relatively easy to drop, sounds like it just needs a new hose fitting. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1074110 26th Aug 2025 7:05pm
Bowbearer
United Kingdom 1985 Defender 110 200 Tdi SW Auto Baltic Blue
Make sure you rust protect the tank whilst it’s off
They tend to rot on the top if you off road in wet mud a lot.
Post #1074347 30th Aug 2025 8:34am
