![]() | Home > Technical > Fuel Gushing Fuel tank Area 110 |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8474 ![]() ![]() ![]() |
Yes. Tank is relatively easy to drop, sounds like it just needs a new hose fitting. Cheers
Bowbearer Member Since: 12 Aug 2022 Location: Norfolk Posts: 234 ![]() ![]() ![]() |
Make sure you rust protect the tank whilst it’s off
They tend to rot on the top if you off road in wet mud a lot. |
DefenderCan Member Since: 25 Nov 2023 Location: Canada Posts: 51 ![]() ![]() ![]() |
Could be the breather hose, known to perish. Usually happens if you overfill the tank. Dropping the tank is easy.
