Home > Puma (Tdci) > Another Issue - Wipers!
ForbesOverland
United Kingdom 2012 Defender 130 Puma 2.2 HCPU Indus Silver
Hi All,
I've been away with work and for one reason or another I havent driven my Defender for probably a month or so.
Jumped in it this morning, went to clear the windscreen and I have water but no wipers! I have checked the fuses and they're fine. I have had a search on the internet and on here, but everyone's issues seem to be that the wipers have moved and then got stuck and mine just arent doing anything!
I am a complete mechnical numpty, so I wondered if there were any other little things to check before I send it off to the garage to get it looked at?
I am really hoping that it isnt the motor as that job looks like a nighmare to do with the dash having to (mostly) come out!
Any advice would be greatly appreciated
Forbes
Post #1074088 26th Aug 2025 1:15pm
ForbesOverland
This Defender has been mostly brilliant, but recently it has really been testing my patience with it seemingly breaking every time I go near it!
Post #1074089 26th Aug 2025 1:18pm
Mo Murphy
Have you tried lifting them off the screen in case they're stuck ?
50 Shades of Pennine Grey
Post #1074094 26th Aug 2025 2:03pm
ForbesOverland
Hi Mo,
Thanks for your reply, I have just tried that, and also sprayed down the spindles with some penetrating oil, but still nothing.
I wondered if perhaps the relay had gone, but I can hear that merrily clicking away too, so I am guessing that it must be the motor that has gone?
Balls.
Post #1074095 26th Aug 2025 2:13pm
Martin
Site Admin
There isn't a relay on the wipers. There's a intermittent delay timer, but it doesn't run the wipers generally, they are wired direct to the switch.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1074097 26th Aug 2025 2:21pm
ForbesOverland
Ahh, got you, thanks Martin (sorry for my lack of mechanical knowledge)
Might have to take it to the garage then!
Post #1074098 26th Aug 2025 2:23pm
gilarion
You could try to see if power is getting to the wiper motor using a voltmeter. If so, then it could be that the motor is stuck or broken. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #1074102 26th Aug 2025 3:42pm
rossy
Hi I'm just guessing that it's the wiper wheel boxes and cable that need replacing. Its quite a primitive set up actually just a toothed disc behind the wiper spindles being spun left and right by a cable (that's more of a long spring) and no matter how well it was greased at installation they just wear out - especially in a wet climate like we have here in Ireland. I got 10 years from mine before the wipers stopped working. It's extremely unlikely to be the motor. Apparently they pretty much last for ever. The good news is that the parts are cheap. The bad news is that the dash does have to come off but find a good Indy if you dont have the confidence to do it yourself and its not that big a job to a good mechanic who will probably have done a few of them by now
Post #1074169 27th Aug 2025 7:40pm
Is the fuse in-tact?
Any sound at all or completely dead? ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1074190 27th Aug 2025 9:39pm
Mr110td5
Post #1076025 23rd Sep 2025 10:55pm
rossy wrote:
... The bad news is that the dash does have to come off ...
No it doesn't. All parts of the wiper system can be removed and replaced with the dash in the vehicle, although it does have to be freed from and pulled away from the bulkhead. Doing it this way negates the need to disconnect as much. It is still a non-trivial job and one some people may find intimidating but it is far from difficult.
The subject has been discussed several times in the past.
Post #1076026 23rd Sep 2025 11:11pm
jst
Did my motor, cable and gearboxes the other month, just moved dash back a bit, still took a while, 3hrs from memory? I had no movement at point of failure.
Motor was probably alright with just worn worm drive and gearboxes but sforza peace of mind I did the lot whilst in there. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1076037 24th Sep 2025 7:16am
hank
Same. It's not that bad a job > 110 XS Double Cab
Post #1076095 24th Sep 2025 8:26pm
I see it as a choice, you can do it with it in place, but I took the entire dash out.
But in my case I had a lot of time spare, and took my time and it was easier to access.
Bearing in mind I had somewhere to keep the dash easy access, if you don’t I’d recommend keeping in place.
In my case I replaced everything, except the rack outer tubes, and the motor.
I did replace the park switch, cable, wheel boxes, arms.
A wiper arm removal tool, is ideal, and beware to cover the glass to prevent a wiper arm possibly slapping it back and breaking the glass. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1076096 24th Sep 2025 8:37pm
Notyalc
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Can you hear the motor running?
Post #1076098 24th Sep 2025 8:48pm
