![]() | Home > Technical > LT conversion - unresponsive accelerator |
eno Member Since: 15 Apr 2024 Location: Qld Posts: 54 ![]() ![]() |
Are the brake switches ok? The switch is probably dual contact with opposite polarity contacts and both need to work correctly, otherwise the ECU could go to limp mode. The same as if you try to drive with the brake pedal depressed slightly.
