Home > Maintenance & Modifications > Water ingress C Pillar
Sfun82
 2009 Defender 110 Puma 2.4 SW Alpine White
G’day everybody!
I’m pretty sure there were posts on this before….finding them seems to be the issue for me.
I have been sealing all around my Puma including alpine windows, gutter, roof panel, the foamy stuff that sits between the body panels all the way around the side and back.
Nevertheless I have water ingress along the C Pillar. Second row and it’s dripping out under the trim where the seatbelts disappear into. I removed the trim and I don’t think it’s coming from the ceiling/roof. More like seeping through the foamy layer mentioned earlier but again I sealed it quite thoroughly there. Door seal has also been addressed. So I’m running out of ideas.
The water is also traveling all the way in the rear corners next to the rear speaker when car is moved.
I’d appreciate if someone could point me the right way…
I did watch a video from the Overland Family where they basically addressed all gaps and areas that could leak and pretty much applied the same job on mine….
Post #1073731 19th Aug 2025 10:43pm
