![]() | Home > General & Technical (L663) > Vertical towball weight |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3505 ![]() ![]() |
So the tow ball can cope with 350kg without modifications but is only certified for 150kg? ls this the fixed or deployable version?
nebc100 Member Since: 07 Nov 2023 Location: Altlinster Posts: 112 ![]() ![]() |
Yes… 100% right
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1360 ![]() ![]() ![]() |
Interesting. So the CoC states 150kg and assuming that the CoC has not been changed, which papers where updated to reflect the 350kg? You country's registration document?
Yes… why car registration papers now have the maximum vertical load set at 350kg.
They have a note that they have been increased in accordance with text XYZ that was done by DEKRA. I just have to keep the DEKRA test with my car papers. |
