![]() | Home > Maintenance & Modifications > Retrofit adjustable headlight |
GeorgeE Member Since: 10 Feb 2025 Location: Wanborough Posts: 26 ![]() ![]() ![]() |
Found this https://www.lrworkshop.com/electrics/defen...-levelling
Looks like my worry that an ECU was involved somewhere was unfounded. So I think my shopping list is: 1. Levelling switch 2. Pair of headlamp bowls that will take the motors 3. Pair of motors 4. Connectors for motors 5. Connect for switch 6. Some wire If I then pick up the feed from the sidelights and an earth, add a liberal dose of swearing, it should all be good. Decision now is either to try and find someone breaking a late Defender that has all the bits or to buy new (though I suspect the connectors my be a challenge to find....) |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 399 ![]() ![]() ![]() |
Hi, once you have the required hardware the wiring should be pretty simple - a nice one pager below from the Td5 wiring diagram. The connectors for the head lamp levelling motors are part number YPC10426. The 6 way connector for the switch might be harder to source - its part number is YPC10004 but you won't find it anywhere. PaulMc posted this on another forum some time back -
https://www.easternbeaver.com/Main/Elec__P...ctors.html ![]() Click image to enlarge |
![]() Click image to enlarge ![]() Click image to enlarge |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6698 ![]() ![]() ![]() |
Connectors aren't a problem, I can supply the 3 way motor connnector and the 6 way switch connector.
