Home > Maintenance & Modifications > Retrofit adjustable headlight
GeorgeE
United Kingdom 1991 Defender 110 200 Tdi CSW Venetian Red
I have a 1991 110 CSW which has had LED headlights fitted (JW Speaker) by the previous owner, the trouble is, they are hopeless. I now know the reason they are hopeless is that the beam has been set based on a fully loaded vehicle, so when it is not fully loaded they are far too low. Now I get that this is the safe approach, no matter what you do you cannot blind someone.
My thinking is, I am sure later defenders had a headlight adjuster knob in the cab, and I am wondering how hard that system would be to retrofit. I am hoping it is just a power feed to the control switch feeding down a set of wires to a motor in each headlight bowl (guessing the headlight bowl is different as well). Has anyone ever done this? Any idea on what parts I actually need as opposed to by guesswork? I've see a thread where someone has retrofitted it to a TD5 where the wiring was already there, but can't find anyone who has done it from scratch.
Post #1073301 13th Aug 2025 7:33pm
GeorgeE
Found this https://www.lrworkshop.com/electrics/defen...-levelling
Looks like my worry that an ECU was involved somewhere was unfounded. So I think my shopping list is:
1. Levelling switch
2. Pair of headlamp bowls that will take the motors
3. Pair of motors
4. Connectors for motors
5. Connect for switch
6. Some wire
If I then pick up the feed from the sidelights and an earth, add a liberal dose of swearing, it should all be good. Decision now is either to try and find someone breaking a late Defender that has all the bits or to buy new (though I suspect the connectors my be a challenge to find....)
Post #1073646 18th Aug 2025 10:57pm
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
Hi, once you have the required hardware the wiring should be pretty simple - a nice one pager below from the Td5 wiring diagram. The connectors for the head lamp levelling motors are part number YPC10426. The 6 way connector for the switch might be harder to source - its part number is YPC10004 but you won't find it anywhere. PaulMc posted this on another forum some time back -
Quote:
Eastern Beaver also sell a 6-way .250" (6.3mm) Yazaki connector that is dimensionally identical to the correct Sumitomo connector and is a perfect fit for this switch
Ref: Connector Set 6PF250 for $4.73 + P&P, here -
https://www.easternbeaver.com/Main/Elec__P...ctors.html
Post #1073665 19th Aug 2025 10:46am
Penfold_6290
Post #1073666 19th Aug 2025 10:53am
Martin
Site Admin
Connectors aren't a problem, I can supply the 3 way motor connnector and the 6 way switch connector.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1073682 19th Aug 2025 1:10pm
