Home > Td5 > Battery strap
2hel
United Kingdom 2003 Defender 90 Td5 CSW Java Black
Battery strap
Ok I've tried searching online to avoid coming across a total newbie but alas here we are!
What's the correct holes for the J rods to go through to clamp the battery down on the TD5. The width between the front holes is too narrow so im assuming I have to run them from the back diagonally to the front of the battery?
Thanks all
Post #1073205 12th Aug 2025 7:49am
jst
Mine are vertical
Some run then diagonally across width of battery
Not seen diagnol front to back Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1073209 12th Aug 2025 8:35am
jst
Battery size obviously has an impact. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1073210 12th Aug 2025 8:35am
2hel
Thanks for the help the battery in mine is quite big but want to add the strap if I can, just the holes look too close for the factory strap. If you or anyone has any pictures that would be great (excuse the cabling im working on it Laughing
Post #1073214 12th Aug 2025 10:49am
2hel
If anyone has or can take some pictures of theirs would be appreciated Thumbs Up
Post #1073323 13th Aug 2025 9:46pm
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
Hi, is this what you're after? Not quite as clean and shiny but hopefully shows what you want?
Post #1073349 14th Aug 2025 10:36am
2hel
Thats perfect thank you Thumbs Up
Post #1073387 14th Aug 2025 6:29pm
