![]() | Home > Td5 > Battery strap |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8471 ![]() ![]() ![]() |
Mine are vertical
Some run then diagonally across width of battery Not seen diagnol front to back Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Battery size obviously has an impact. Cheers
2hel Member Since: 28 Nov 2022 Location: Essex Posts: 190 ![]() ![]() ![]() |
Thanks for the help the battery in mine is quite big but want to add the strap if I can, just the holes look too close for the factory strap. If you or anyone has any pictures that would be great (excuse the cabling im working on it
![]() ![]() Click image to enlarge ![]() Click image to enlarge |
If anyone has or can take some pictures of theirs would be appreciated
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 400 ![]() ![]() ![]() |
Hi, is this what you're after? Not quite as clean and shiny but hopefully shows what you want?
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Thats perfect thank you
