![]() | Home > Td5 > Steering Tension Point |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3605 ![]() ![]() ![]() |
Ask them to make roundabouts that you go around clockwise, so you bed in the steering
![]() Sorry, I am sure that will not help. Perhaps you can pop off the drag link from the steering drop arm, and check if the so called tension point can still be felt. This would tell you if its a box issue of steering linkages/swivel issue. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5991 ![]() ![]() |
My starting point would be to remove the steering damper, check it’s installation and operation.
