![]() | Home > Maintenance & Modifications > Windscreen sealing |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4337 ![]() ![]() ![]() |
I'm thinking this might be the stuff I need
https://refinishsystems.com/product/3m-win...f74G4sabPo 2007 110 TDCi Station Wagon XS |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18006 ![]() ![]() ![]() |
The windscreens seals were, I am told, "value-engineered" during the production of the old Defender, and the value-engineered seals leave a lot to be desired both in terms of their sealing ability and their durability. My local independent windscreen fitted advised that if you have early seals in good condition, then don't replace them. If you have the later type (or aftermarket seals) expect to replace them every few years.
Mine is a genuine one, not sure of when it was made as I bought NIB off another forum member a couple of years ago. It is not cracked or perished, it just isn't keeping the water out. 2007 110 TDCi Station Wagon XS
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1917 ![]() ![]() |
The place that last did mine used/recommended a stuff called ‘arbomast’. I got a couple of tubes and I think it’s OK - may not be much different to anything else of the same ilk tho’. Donald
1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2543 ![]() ![]() ![]() |
It seems that arbomast was developed for the marine market but appears to be only available in grey. Defender 90XS SW
