![]() | Home > Td5 > Wheel bearing at 12 o clock and 6 o clock? |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2237 ![]() ![]() ![]() |
Is it front or rear?
If its rear and you have the two nut system then yes, however be prepared to change in the not too distant future. If its the single stake nut then you should replace. Timken only with corteco seals. If its front, wedge the brakes on and check again. If the play remains it would indicate swivel bearings need adjustment or replacement. As above Timken only. |
roche1800 Member Since: 07 Apr 2020 Location: derbyshire Posts: 439 ![]() |
Sorry! It’s the front drivers side and it was done with no brakes applied.
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8471 ![]() ![]() ![]() |
If only at 12 and 6 then swivel bearings Cheers
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 999 ![]() ![]() ![]() |
Agreed… As previously posted if only at the 6+12 position it is the swivel bearings, not the wheel bearings.
Good luck 2020 range Rover Mk IV Autobiography PHEV 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
