Home > Td5 > Wheel bearing at 12 o clock and 6 o clock?
roche1800
My td5 when jacked up has very very slight movement when you rock it at 12 o clock (top) and 6 o clock (bottom).
Is it just simply take the wheel off and tight the centre nut with a 52mm socket.
Thanks in advance
Post #1072685 2nd Aug 2025 12:46pm
bankz5152
Is it front or rear?
If its rear and you have the two nut system then yes, however be prepared to change in the not too distant future. If its the single stake nut then you should replace. Timken only with corteco seals.
If its front, wedge the brakes on and check again. If the play remains it would indicate swivel bearings need adjustment or replacement. As above Timken only.
Post #1072687 2nd Aug 2025 1:08pm
roche1800
Sorry! It’s the front drivers side and it was done with no brakes applied.
Post #1072690 2nd Aug 2025 3:32pm
jst
If only at 12 and 6 then swivel bearings Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1072702 2nd Aug 2025 10:28pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Agreed… As previously posted if only at the 6+12 position it is the swivel bearings, not the wheel bearings.
Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #1072731 3rd Aug 2025 6:25pm
