Home > Maintenance & Modifications > Castor correction
Joeytf
Castor correction
I am going to change my front 10 spline axle to a 24 spline.
I have 3 inch lift and currently have the the narrow cranked radius arms.
New front axle has slight pitting on swivels, my question is….. if I bought castor corrected swivels, would that solve me needed cranked radius arms?
Thanks
Post #1072327 27th Jul 2025 11:36pm
TexasRover
I would keep the axle stock and play with the radius arms instead:
- If ever in future you move the axle to another vehicle you might get very confused
- Modified radius arms are easier (cheaper) to get than modified swivels?
- The U-joint alignment should be easier to manage when diff and transfer case are in the same correct plane
3" lift is quite a lot. I would not think that would be a very good drive on the road, but to each their own. What are you trying to achieve?[/list]
Post #1072330 28th Jul 2025 8:44am
Joeytf
To fit my 285’s under it.
I already have gwyn Lewis wide angle props, cranked rear arms and lift kit
Post #1072371 28th Jul 2025 6:21pm
Jurassic Defender
Portugal 2000 Defender 110 2.5 TD HT Coniston Green
If its any help, I have a video replacing the front Radius arms for the Terrafirma with Caster correction:
https://youtu.be/HjobgX5vTiA?si=cL6fqVBUAIAe-SVg
Post #1072487 30th Jul 2025 11:54am
