![]() | Home > Maintenance & Modifications > Castor correction |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1304 ![]() ![]() ![]() |
I would keep the axle stock and play with the radius arms instead:
- If ever in future you move the axle to another vehicle you might get very confused - Modified radius arms are easier (cheaper) to get than modified swivels? - The U-joint alignment should be easier to manage when diff and transfer case are in the same correct plane 3" lift is quite a lot. I would not think that would be a very good drive on the road, but to each their own. What are you trying to achieve?[/list] |
Joeytf Member Since: 20 Sep 2024 Location: Somerset Posts: 40 ![]() ![]() |
To fit my 285’s under it.
I already have gwyn Lewis wide angle props, cranked rear arms and lift kit |
Jurassic Defender Member Since: 28 May 2025 Location: Lisbon Posts: 12 ![]() ![]() ![]() |
If its any help, I have a video replacing the front Radius arms for the Terrafirma with Caster correction:
https://youtu.be/HjobgX5vTiA?si=cL6fqVBUAIAe-SVg ![]() Click image to enlarge |
