![]() | Home > Maintenance & Modifications > Thread sealing products - Loctite, Hylomar, Permatex etc. |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2524 ![]() ![]() |
I use Loctite 248 (stick) and Hylomar blue on diff, transfer and gearbox plugs. I use on just the cleaned plug threads, and yes you can never stop the drips on the casing threads but they seal fine with the tread locker or sealant on just the cleaned male plug threads. Just adhear to the correct torque when nipping up.
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3638 ![]() ![]() ![]() |
You may use Loctite 55 or just a normal ptfe tape.
I use the latter but apparently the Loctite 55 is much easier to clean off the threads next time you need re fit. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
