![]() | Home > Technical > 300 TDi AirBox Clamps |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1909 ![]() ![]() |
I don’t think they will I’m afraid. I think the Donaldson/Wolf filter canister is a larger diameter. I think the standard canister wouldn’t be held properly.
That said, there’s nothing really wrong with substantial tie wraps, and you could probably buy the Wolf straps and modify it. I think I’d want some rubber bobbin mountings in there somewhere. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
breadturbo Member Since: 30 Mar 2025 Location: West Yorkshire Posts: 15 ![]() ![]() ![]() |
Can't tell you about the donaldson's im afraid, but i got a pair from an auction site after spending ages looking also, very hard to find.
They were £78 each (ERR4688) plus a fiver for cotton reels, previouslt it was held in by one seatbelt like rubber strap sat on the metal mounting plate, they have made a noticeable reduction in rattles for me. Yes my engine bay is a work in progress ![]() ![]() Click image to enlarge |
Gedd Member Since: 17 Sep 2022 Location: Devon Posts: 14 ![]() ![]() ![]() |
Many thanks for your info, I am presuming the bobbin/cotton reels secure and stop vibrations?? I have a few noises thinking that probably why 1995 Defender 110 300 TDi Hard Top Rutland Red
2014 Evoque Dynamic Metallic Blue |
Thanks Donald 1995 Defender 110 300 TDi Hard Top Rutland Red
the pipe that goes form the dump into the airbox is completely shredded wondered if that is due to the airbox vibrating cos it isn't held down 1995 Defender 110 300 TDi Hard Top Rutland Red
Hiya,
Yes the bobbins are the rubber feet you can see under the clamps, they are quite flexible compared to the single! old one i had on there. I am not sure which pipe you mean that is shredded? There is one intake pipe into the bottom of the airbox (from the snorkel on mine) Then the big pipe you see on my pic goes direct to the turbo (i changed mine for a non-egr one as the stock one has a small open pipe on the top and it was starting to go a bit crusty. There is the pipe from the black plastic crank ventilation thingy on the head that goes underneath and into the pipe from box to turbo, this is clamped to the back of the head just out of view. thanks James |
Thanks James,
Its the pipe that comes from the air intake I have a snorkel too, goes into the bottom of the airbox will take a photo ![]() Click image to enlarge Picture 1 I have lifted airbox up pipe is in half ![]() Click image to enlarge ![]() Click image to enlarge picture 2 3 This is what I could see 1995 Defender 110 300 TDi Hard Top Rutland Red 2014 Evoque Dynamic Metallic Blue |
Hiya,
Yes that section definitley needs replacing and could very well be because of airbox moving, i could see it rubbing on the side of the mount plate (you have half of your cotton reels there ![]() It also looks like a think pipe, i am not sure which is stock however being new to 300tdi's myself, mine have all been replaced with silicone hose. But for sure the new clamps are reels hold it nice and snug, they are ££ but worth it in my opinion as a one off thing. thanks James |
I think it is the original hose, I have a replacement, couldn't find silicon hoses for that particular hose, does it need to be flexible? just ordered some used straps/brackets of Ebay and some bobbins,
many thanks Ged 1995 Defender 110 300 TDi Hard Top Rutland Red 2014 Evoque Dynamic Metallic Blue |
I dont think it needs to the flexible no, at least not much, the airbox moves 1/2" on the cottonreels and the dump pipe is on a bracket at the wing side i believe.
Make sure to check them all if you are doing them, a couple of mine were delaminating badly (inc the main airbox to turbo hose) and dont forget the bonnet comes off, i spent an hour trying to fiddle behind there laid on the rocker cover before the mrs said ' hey does that come off' ![]() thanks James |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6703 ![]() ![]() ![]() |
The clasps just look like seat box lid clasps MRC8388
An easier alternative to taking it off completely is just to unpin the bonnet support strut, and lay the bonnet up against the windscreen. I do this a lot, and over the years I can’t think of many jobs I’ve done where this access wasn’t sufficient. I usually use something soft like a towel/fleece between the bonnet and the windscreen wipers, and tie or bungee it against the roof bars. If you’ve no roof bars, the B pillar would do. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
