Home > Tdi > De mister bungs on a 300 TDi
Gedd
United Kingdom 1995 Defender 110 300 Tdi HT Rutland Red
replacing the tubes to the windscreen demister, having a problem fitting the tube to the "bungs' at the bottom because they are too soft, anyone have advice, experience etc. 1995 Defender 110 300 TDi Hard Top Rutland Red
2014 Evoque Dynamic Metallic Blue
Post #1072131 24th Jul 2025 5:03pm
donmacn
Apologies if this is a hugely obvious question - but are you fitting them with the corrugated tubes to the windscreen going down inside the ducting grommets (bungs)? So that the rubber is on the outside?
And again, apols if too obvious, but they’re not bungs as such - they are where the hot air comes from - but maybe that’s just a question of terminology.
I can’t say I’ve ever had any particular issue doing this - apart from finding that the tubes can be just a little bit short. I’ve tried both ways - fitting the tubes into the grommets, then up onto the demisters, or the other way round. I can’t really say whether one way was any easier than the other.
Maybe some pics if it continues to be a problem? Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #1072138 24th Jul 2025 6:48pm
Gedd
Thanks, I tried to put the old ones back on a few weeks and the bungs were soft and effected putting back, have new ones, yet to try them, will update once I have. maybe overthinking it 1995 Defender 110 300 TDi Hard Top Rutland Red
Post #1072139 24th Jul 2025 6:51pm
Mo Murphy
Patience.
50 Shades of Pennine Grey
Post #1072152 25th Jul 2025 5:32am
jim4244
England 2013 Defender 90 Puma 2.2 CSW Fuji White
Hi
Not too sure what these "bungs" are that you keep referring to?
can you post a pic?
Jim
Post #1072153 25th Jul 2025 5:41am
Gedd
They are called that on the tech diagram
no 5
dont seem to upload the parts list attached to this diagram 1995 Defender 110 300 TDi Hard Top Rutland Red
Post #1072162 25th Jul 2025 7:54am
donmacn
That’s interesting - where did you get that one?
I can’t do anything complicated like screenshots on this device (iPad) - I’m sure the iPad can, just that I don’t know how…..
I went to LrCat (Google ‘new lr cat’) and on the same diagram, that part is listed as a grommet.
Not that any of this matters or helps.
Try fixing the pipes to the demisters first, then see if you can get the pipe into the grommet/bung at the back first, and then work your way round both sides teasing the grommet over the end of the pipe. Donald
in the past..
Post #1072166 25th Jul 2025 8:57am
Gedd
Seen! Grommets is a better description, dont know why my diagram says Bungs?? 1995 Defender 110 300 TDi Hard Top Rutland Red
Post #1072180 25th Jul 2025 11:49am
