![]() | Home > Tdi > De mister bungs on a 300 TDi |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1917 ![]() ![]() |
Apologies if this is a hugely obvious question - but are you fitting them with the corrugated tubes to the windscreen going down inside the ducting grommets (bungs)? So that the rubber is on the outside?
And again, apols if too obvious, but they’re not bungs as such - they are where the hot air comes from - but maybe that’s just a question of terminology. I can’t say I’ve ever had any particular issue doing this - apart from finding that the tubes can be just a little bit short. I’ve tried both ways - fitting the tubes into the grommets, then up onto the demisters, or the other way round. I can’t really say whether one way was any easier than the other. Maybe some pics if it continues to be a problem? Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Gedd Member Since: 17 Sep 2022 Location: Devon Posts: 14 ![]() ![]() ![]() |
Thanks, I tried to put the old ones back on a few weeks and the bungs were soft and effected putting back, have new ones, yet to try them, will update once I have. maybe overthinking it 1995 Defender 110 300 TDi Hard Top Rutland Red
2014 Evoque Dynamic Metallic Blue |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2416 ![]() ![]() ![]() |
Patience.
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 998 ![]() ![]() ![]() |
Hi
Not too sure what these "bungs" are that you keep referring to? can you post a pic? Jim |
They are called that on the tech diagram
![]() no 5 dont seem to upload the parts list attached to this diagram 1995 Defender 110 300 TDi Hard Top Rutland Red 2014 Evoque Dynamic Metallic Blue |
That’s interesting - where did you get that one?
I can’t do anything complicated like screenshots on this device (iPad) - I’m sure the iPad can, just that I don’t know how….. I went to LrCat (Google ‘new lr cat’) and on the same diagram, that part is listed as a grommet. Not that any of this matters or helps. Try fixing the pipes to the demisters first, then see if you can get the pipe into the grommet/bung at the back first, and then work your way round both sides teasing the grommet over the end of the pipe. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Seen! Grommets is a better description, dont know why my diagram says Bungs?? 1995 Defender 110 300 TDi Hard Top Rutland Red
