Home > Maintenance & Modifications > Cargo Rails
8619simon
Wales 1995 Defender 110 300 Tdi CSW Epsom Green
Cargo Rails
I want to fit cargo rails to my 300tdi 110 CSW on the Driver side rear window panel. I've got the MUD UK slimline rails which fit nicely on the outside but where the bolt hole would fall is right on the join of the inner flange.
Has anybody else had this? I was hoping the bolt holes would fit between the flange and the window frame.
Any suggestions for a work around would be welcome. I had thought of using Rivnuts and accepting they will sit on the join?
Simon
Pic shows the flange I mean but is not my actual panel. The rivet you can see in the pic is in about the same position as mine so when you consider the lowest point on the outside frame of the window will be below the rivet, there seems to be no way to avoid this flange joint?
Post #1072056 23rd Jul 2025 12:09pm
excossack
Do the cargo rails have to go there?
This is my setup if it helps
The metal bar going across with the 4 vertical tubes where for another idea that didn't happen 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1072059 23rd Jul 2025 1:32pm
8619simon
Sorry my bad... The cargo rails will go on the outside... like this:
It is the bolts as they come through that I am having an issue with.
Like your solution internally though Thumbs Up
Thanks
Simon
Post #1072063 23rd Jul 2025 1:54pm
excossack
Ahh that does some what alter the idea.
Make a plate that goes under the window attach this to the side and using counter sunk bolts to mount the cargo rails to ? 1999 Defender TD5 110
Regards
John M0VAZ
Post #1072064 23rd Jul 2025 2:02pm
