![]() | Home > Maintenance & Modifications > Cargo Rails |
| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6043
Do the cargo rails have to go there?
This is my setup if it helps Click image to enlarge The metal bar going across with the 4 vertical tubes where for another idea that didn't happen 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
| 8619simon Member Since: 05 Nov 2016 Location: North Wales Posts: 265
Sorry my bad... The cargo rails will go on the outside... like this:
Click image to enlarge It is the bolts as they come through that I am having an issue with. Like your solution internally though Thanks Simon |
Ahh that does some what alter the idea.
Make a plate that goes under the window attach this to the side and using counter sunk bolts to mount the cargo rails to ? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
