![]() | Home > Maintenance & Modifications > Door handle (exterior) help required |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1917 ![]() ![]() |
Hi Phil,
I can't comment on the alu. versions you've mentioned. I did go Optimill in the end, mainly because of the more secure key/lock they used. However prior to this I had real issues fitting a "quality" set of plastic handles. They were just too big (long) for the door cut outs, hence the bending in the middle and the gap you've highlighted. I took some pics and waffled on about it in my 'rebuild' thread. On this page:https://www.defender2.net/forum/topic58538-75.html Hope that's of some use. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1353 ![]() ![]() ![]() |
Inevitably there are poor quality/fit parts available on the market. There is a enough of a draw to make parts since there is a demand, but at the same time its not as if we are all willing pay top dollar so if it's cheap, quality can be questionable.
It does not surprise me your plastic replacement parts are a poor fit. Personally I prefer 'used original' (typically from my private stash) over cheap aftermarket where I can. The safer bet is to go to specialist suppliers, at a higher price, but often these are better than original. However there are also good parts out there so don't give up. Just admit defeat sometimes. Call it the 'thrill of the case', of classic car ownership. |
300TDi CSW Phil Member Since: 03 Apr 2016 Location: Bracknell Posts: 862 ![]() ![]() ![]() |
Thanks chaps.
I have given up on plastic ones and hit the button ![]() I will offer one up when they arrive to one of the second row doors from DDS and assuming it lines up properly they will be staying. Hopefully the finish isn't too different to the front Optimill hinges but at this point that is a secondary concern as I just want handles that fit properly and the 2nd row hinges I have are silver so need to be turned into black anyway. Once I have one (or more fitted) they will be be pictured in my colour change thread. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper. Wide Track Sankey- In bits- Gone to a new home M0XQS |
