Home > Technical > TD5 10AS issue
LJMARSDEN
United Kingdom 2006 Defender 90 Other HT Java Black
TD5 10AS issue
Hi all,
I have recently taken the TD5 turned V8 off of the road as I now have bigger commute to deal with and the fact a few issues have arised.
It looks like the central locking and 10AS has failed? Neither of my two keys function. The necessary functions are receiving 12volts.
Anyone experienced this? any suggestions would be great beforeI send the unit off for inspection.
NOTE: I am going to going on the timeless overland tour to france next year, looking to remedy everything slowly.
thanks 4.0 V8 Defender 90
My Instagram
Post #1071900 21st Jul 2025 2:57pm
markb110
Might be worth checking the wiring that runs through the conduit to see if there is a break in the (very thin) wiring.
My problem at the time was the door once locked with the key fob would just unlock itself straight away. From memory there are four of the thin wires that run from the door to the bulkhead. For me it was the yellow wire that had failed.
I did not bother with a new loom, just repaired the break.
I am sure that someone here can pinpoint the actual cause of the problem.
Good luck
Thumbs Up
Post #1071916 21st Jul 2025 4:10pm
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
First thing to try is new batteries in your fobs...it sounds unlikely but a few months ago in cold weather I paid the local independent guy nearly £100 to come out and tell me the alarm was fine, my fobs weren't transmitting. Two new batteries later and all fine - doh!
Once you've eliminated that and all you've checked continuity between switches, doors and ECU it might be a case of send the AS10 off for surgery. These folks seem to crop up in these pages quite often -
https://www.remotekey.co.uk/shop/land-rove...trol-ecus/
Post #1071971 22nd Jul 2025 9:44am
LJMARSDEN
Thanks for the reponse.
The car is undergoing some upgrades now with them being a puma bulkhead and loom. I'll tackle this issue during this time. 4.0 V8 Defender 90
My Instagram
Post #1072215 25th Jul 2025 10:57pm
