Home > Wheels & Tyres (L663) > speed restrictions 22" vs 20"
asaf
Israel
hi
I have V8 2022 defender.
it came with 22" wheels and i bought an extra set of 20" for off roading
i know the tire limit
do i need or can i change the speed limits of the car?
does the car do it by itself?
is the wheel size the car was delivered from landrover has the limit effect?
thanks
Post #1071862 21st Jul 2025 9:19am
steam_simon
The speed remains the same. The circumference of a 22” and 20” inch wheel are the same if you use the correct tyres.
Post #1072242 26th Jul 2025 3:03pm
Nuclear Nick
Simon, if I'm understanding the OP's question correctly it's that the smaller diameter off road tyre has a lower speed rating than the standard fit 22's and can the lower limit be manually set into the car's speed limiter or, does entering the new size change the limiter or does the car sense the new tyre speed limit and automatically adjust the limiter?
I'm not aware of any of those options being available, at least except via diagnostics maybe? 23.5MY 90 V8 Carpathian grey
Post #1072263 27th Jul 2025 6:45am
asaf
Israel
thanks for trying to help
with the 22" the speed limit is the car top speed
with the 20" the speed limit is 196 KP"H
regardless the specific limit of the tiers
does the car knows and changes the limit with the change of wheels from 22 to 20?
?si=Vf-ltoRZDoYiNCrk
you can see in this video that the guy from lucky8 say that they bought the Octa with 22" for no speed restrictions
Post #1072265 27th Jul 2025 7:25am
plumpmoose
The Octa allows buyer to specify 2 20inch all terrain tyres. One is limited to a lower speed than the other. And more capable off road.
Think video from Harry Garage goes into the detail.
The vehicle will not know this. However if telematics indicate speed was higher than tyres specified, you crash, then you might not be insured etc.
Post #1072341 28th Jul 2025 11:11am
asaf
Israel
if i understand the car will not stop accelerating regardless size of rim?
i will not try to go over the limit i want to make sure that with changing to 22 the car is not limited from factory.
thank a lot
Post #1072346 28th Jul 2025 11:59am
