Home > Puma (Tdci) > Progressive coils
Eduardo
Progressive coils
We have a doubt with MK regarding the progressive coils.
The upper part of the front coils appear to be touching each other. This is OK?
see the picture.
Are yours looks similar?
Thanks Eduardo
Post #7695 24th Feb 2009 3:50am
mhasting2004
Australia 2008 Defender 110 Puma 2.4 SW Stornoway Grey
Hi Eduardo
Just went out to check mine... same deal, no progressive usable. Mine has an ARB bullbar (no winch) on the front so not entirely supprised but a bit dissapointed as this just means I need to change springs sooner. Old TD5 had ARB shocks and coils put on after I broke one rear shock. They (the ARB's) were not progressive though.
Mark
2008 Puma
Post #7701 24th Feb 2009 9:16am
alantd
I think that's the standard set-up.
If you completely extended the spring, you'd see that it is progressive IIRC. One that started out as a 2.4 TDCi 110 XS
Post #7707 24th Feb 2009 10:26am
Eduardo
This is just that we are trying to confirm if this is the normal setup or not.
Thanks Eduardo
Post #7723 24th Feb 2009 3:22pm
MK
I would say the only way to check this out is by looking at a brand new unit that has not been sitting at the stealer longer than two weeks Razz
 Puma 110" SW
Post #7725 24th Feb 2009 3:36pm
Eduardo
After checking other information in other sites appears to be OK as it is.
If you like to check the suspension height:
Front: 72 ± 15 mm
Rear: 130 ± 15 mm
Thanks to all. Eduardo
Post #7736 25th Feb 2009 1:27am
MK
+/-15mm is quite a big (LR) error. Those +15 mm account probably for the separation on new springs. Puma 110" SW
Post #7737 25th Feb 2009 2:27am
