![]() | Home > Puma (Tdci) > Progressive coils |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2112 ![]() ![]() ![]() |
We have a doubt with MK regarding the progressive coils.
The upper part of the front coils appear to be touching each other. This is OK? see the picture. ![]() Click image to enlarge Are yours looks similar? Thanks Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
I think that's the standard set-up.
If you completely extended the spring, you'd see that it is progressive IIRC. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
This is just that we are trying to confirm if this is the normal setup or not. Thanks Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2503 ![]() ![]() ![]() |
After checking other information in other sites appears to be OK as it is.
If you like to check the suspension height: Front: 72 ± 15 mm Rear: 130 ± 15 mm Thanks to all. Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
+/-15mm is quite a big (LR) error. Those +15 mm account probably for the separation on new springs. Puma 110" SW
