![]() | Home > Td5 > Cooling fan |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6043 ![]() ![]() |
The fan will spin but the difference is if the fan clutch is locked in or not.
Mr.Jimbo Member Since: 20 Jun 2024 Location: Rugby UK Posts: 35 ![]() ![]() ![]() |
As long as it then stops running before it does warm up, this is a characteristic of a viscous fan. I think, and could be wrong, it might be all the fluid falling to the bottom of the chamber and blocking the vanes thus locking the fan “on” as if it were warm.
Should go away quite quickly once the fan has rotated and redistributed the fluid again until such a time as it’s heated up and the fan locks as it should, if it’s just on all the time then you’ve got an issue |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2237 ![]() ![]() ![]() |
Roll up a news paper tight as possible.
Introduce it to the fan when cold. If the fan stops happy days. If not then probably needs a new fan. |
