Home > Td5 > Cooling fan
tony.g
Cooling fan
2005 Td5; water cooling fan starts running immediately engine is turned on from cold. Is this normal?
I thought it only starts running when the water heats up.
Post #1071762 19th Jul 2025 10:53pm
landy andy
The fan will spin but the difference is if the fan clutch is locked in or not.
Post #1071765 20th Jul 2025 2:28am
Mr.Jimbo
United Kingdom 2003 Defender 110 Td5 CSW Java Black
As long as it then stops running before it does warm up, this is a characteristic of a viscous fan. I think, and could be wrong, it might be all the fluid falling to the bottom of the chamber and blocking the vanes thus locking the fan “on” as if it were warm.
Should go away quite quickly once the fan has rotated and redistributed the fluid again until such a time as it’s heated up and the fan locks as it should, if it’s just on all the time then you’ve got an issue
Post #1071788 20th Jul 2025 12:51pm
bankz5152
Roll up a news paper tight as possible.
Introduce it to the fan when cold. If the fan stops happy days. If not then probably needs a new fan.
Post #1071795 20th Jul 2025 1:33pm
