![]() | Home > Maintenance & Modifications > Getrag 420g gearbox and lt230 transfercase |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 843 ![]() ![]() ![]() |
Is there a 420 on any other car with a transfer case? I know the bell housing for the 6cyl is different to the 8 cyl but the x5 can have a manual gearbox but don’t know if that’s the 420, but then you would need to change the bell housing if that’s possible Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details |
T3DDY14 Member Since: 23 Jul 2020 Location: Kent Posts: 35 ![]() ![]() ![]() |
It only came in the e39 m5, 540i and e46 m3 all were rwd,
Other option would be convertinv it to rwd? |
Found that the early x5s came with a transfercase lwx500 that supplsedly fits the getrag 420g, if this is the case would i just need custom props to go from the transfercase to axles
I would guess an auto box then.
But I know the drift guys use a manual gearbox on the m62 that’s not standard, maybe that’s an option. Fits with a plate between engine and gearbox but allows the 6 speed manual from a diesel and maybe that one was on a x5 or other 4x4 Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
