![]() | Home > Technical > What's this noise please? |
tobias6 Member Since: 17 Jan 2025 Location: Oxfordshire Posts: 26 ![]() ![]() ![]() |
I have an intermittent squeal when accelerating (sometimes steady speed as well) at low speeds, I don't think it's the belt as it's road speed dependant not RPM dependant and can only be heard whilst in gear.
I've made a video where i am repeatedly pressing and letting off the accelerator to get a good recording of the noise https://www.youtube.com/shorts/YsCvIZIc-Ug I had recently put on 30mm spacers all round but now taken them off as they were causing so much vibration so maybe they have put some strain on the drivetrain somewhere to cause this noise? Let me know what you think! 2010 90 Hardtop 1991 RR Vogue SE |
No nothing like that, the car drives and feels perfectly normal. The clutch was replaced last April so I’d like to think that can ruled out
Thanks for your response 2010 90 Hardtop 1991 RR Vogue SE |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 400 ![]() ![]() ![]() |
I've listened to it again (and again) and the sound reminds me of a tractor I used to drive that had a dry bearing in the ventilation fan...I doubt it's that. lol
Can you replicate it when stationary or only when moving? Does the pitch rise as your speed increases? Does it do it in every gear? Does it do it in low range? |
It’s definitely only when moving, the pitch does change with road speed but it’s only a small band of speeds where the noise can be heard hence the short squeals in the video as I accelerate though that particular speed (it’s around 25-30mph)
I haven’t tested in low range but I can do so tomorrow Cheers 2010 90 Hardtop 1991 RR Vogue SE |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3641 ![]() ![]() ![]() |
The UJs on the prop shafts can make strange noises. Try to grease them. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18024 ![]() ![]() ![]() |
Check the integrity of the pipes from the turbo to the intercooler and intercooler to manifold, and the intercooler itself. It could be a leak in a hose squealing under pressure.
Will give that a go Cheers 2010 90 Hardtop 1991 RR Vogue SE |
Thanks I’ll check this T 2010 90 Hardtop 1991 RR Vogue SE |
Thanks for pointing out the UJ, the rear one on the front prop is completely shagged so I think that’s probably the culprit 👍 2010 90 Hardtop 1991 RR Vogue SE |
