Home > Technical > What's this noise please?
tobias6
United Kingdom 2010 Defender 90 Puma 2.4 HT Tamar Blue
I have an intermittent squeal when accelerating (sometimes steady speed as well) at low speeds, I don't think it's the belt as it's road speed dependant not RPM dependant and can only be heard whilst in gear.
I've made a video where i am repeatedly pressing and letting off the accelerator to get a good recording of the noise https://www.youtube.com/shorts/YsCvIZIc-Ug
I had recently put on 30mm spacers all round but now taken them off as they were causing so much vibration so maybe they have put some strain on the drivetrain somewhere to cause this noise?
Let me know what you think! 2010 90 Hardtop
1991 RR Vogue SE
Post #1071119 9th Jul 2025 4:05pm
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
Any symptoms of the clutch slipping maybe? Are the revs rising by a greater rate than the speed is increasing when you accelerate?
Post #1071121 9th Jul 2025 4:31pm
tobias6
No nothing like that, the car drives and feels perfectly normal. The clutch was replaced last April so I’d like to think that can ruled out
Thanks for your response 2010 90 Hardtop
1991 RR Vogue SE
Post #1071123 9th Jul 2025 4:37pm
Penfold_6290
I've listened to it again (and again) and the sound reminds me of a tractor I used to drive that had a dry bearing in the ventilation fan...I doubt it's that. lol
Can you replicate it when stationary or only when moving? Does the pitch rise as your speed increases? Does it do it in every gear? Does it do it in low range?
Post #1071126 9th Jul 2025 4:44pm
tobias6
It’s definitely only when moving, the pitch does change with road speed but it’s only a small band of speeds where the noise can be heard hence the short squeals in the video as I accelerate though that particular speed (it’s around 25-30mph)
I haven’t tested in low range but I can do so tomorrow
Cheers 2010 90 Hardtop
1991 RR Vogue SE
Post #1071132 9th Jul 2025 5:15pm
Dinnu
The UJs on the prop shafts can make strange noises. Try to grease them. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1071141 9th Jul 2025 8:53pm
Check the integrity of the pipes from the turbo to the intercooler and intercooler to manifold, and the intercooler itself. It could be a leak in a hose squealing under pressure.
Post #1071154 9th Jul 2025 10:26pm
tobias6
Will give that a go
1991 RR Vogue SE
Post #1071160 10th Jul 2025 12:25am
tobias6
Thanks I’ll check this
T 2010 90 Hardtop
1991 RR Vogue SE
Post #1071161 10th Jul 2025 12:25am
