![]() | Home > Td5 > Panhard Rod / Track Bar Not Lining Up |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1909 ![]() ![]() |
I think you might benefit from putting the weight back on the axle to be honest. Do you have anything like a “ratchet strap” you could use to realign them?
In the past I’ve used long joinery clamps to do this, where there was some movement - but I can’t remember if that was Defender or Range Rover - not that it makes much difference. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2675 ![]() ![]() ![]() |
When I did mine and had the same issue I was working inside my garage.
I found the best way was to move the body over. As I was on my own, I used a bottle jack up against the wall with a block of wood and a kneeling foam pad to protect the wing, pumped up the jack then once ready just popped the bolt through. If you have a spare ‘volunteer’ get them to push the front wing until you get the same result. Good luck |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3604 ![]() ![]() ![]() |
If you put the wheels back, and wheels on the ground, you could use the steering to pull or push accordingly. As long as the drag link is still fitted of course. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Mr.Jimbo Member Since: 20 Jun 2024 Location: Rugby UK Posts: 18 ![]() ![]() ![]() |
From memory when I did mine, a tapered punch was enough for me to lever the chassis/panhard bush hole over enough in order to line the holes back up, maybe with a small extension on it, but I don't remember it being that difficult, did mine with wheels on the ground not jacked up.
paul 123 Member Since: 10 Jul 2022 Location: norwich Posts: 146 ![]() ![]() ![]() |
turn the steering with the wheels on the ground and i will align it
tommobot Member Since: 15 May 2018 Location: Stratford Upon Avon Posts: 43 ![]() ![]() |
Litterally just did exactly this...
Fitted an bolted the inner (higher) side, then jacked up this side under the axle and the other side lined up eventually and bolt slid through.. |
CJs110 Member Since: 06 Sep 2023 Location: Windsor Posts: 26 ![]() ![]() ![]() |
Thanks everyone for the insight. I followed as mentioned put the vehicle back on its own weight wheels on the ground.
Didn't have a second person to push the wing with, so used the steering method - rocked wheel back and forth, went under checked if it was aligned (repeated a few times lol) but eventually it lined back up!! Watching the body shift over while the wheels stay put is a very odd sensation - but it really show just how much the axle had shifted!! Thanks again all |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 988 ![]() ![]() ![]() |
Use a ratchet strap of you are alone. Simplest way.
Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5351 ![]() ![]() |
Yeah my dad did this with a strap, so that i could get the bolt in. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
