Home > Td5 > Panhard Rod / Track Bar Not Lining Up
CJs110
Canada 2003 Defender 110 Td5 SW Zambezi Silver
Long story short, had some death wobble so I bought new bushings for panhard rod / trackbar (sorry I use that term coming from Jeeps) and swivel pins/shims. Decided to start with the panhard rod, poly bushing in place of original.
Old ones pressed out. New ones were fitted in - no issues.
Then went to install, got one side in (bolt thru) then tried to line it up with the other side and it would. The holes are way off!! Its as though the axle has shifted (I did this with wheels on the ground, but wondering if my hammering/utilizing a jack as a lever to push the rod up shifted the axle??)
How can I line the axle back up so that the trackbar fits into place? I took the weight off the front suspension (stands under the frame, wheels off, axle sitting on jack) and tried to move the axle - no luck.
Any advice? Pictures below. Doesnt matter if I attach from the other side first, second hole doesnt line up.
Post #1070991 7th Jul 2025 7:45pm
donmacn
I think you might benefit from putting the weight back on the axle to be honest. Do you have anything like a “ratchet strap” you could use to realign them?
In the past I’ve used long joinery clamps to do this, where there was some movement - but I can’t remember if that was Defender or Range Rover - not that it makes much difference. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #1070992 7th Jul 2025 7:54pm
markb110
When I did mine and had the same issue I was working inside my garage.
I found the best way was to move the body over.
As I was on my own, I used a bottle jack up against the wall with a block of wood and a kneeling foam pad to protect the wing, pumped up the jack then once ready just popped the bolt through.
If you have a spare ‘volunteer’ get them to push the front wing until you get the same result.
Good luck
Post #1070993 7th Jul 2025 7:55pm
Dinnu
If you put the wheels back, and wheels on the ground, you could use the steering to pull or push accordingly. As long as the drag link is still fitted of course. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1071003 7th Jul 2025 9:05pm
Mr.Jimbo
United Kingdom 2003 Defender 110 Td5 CSW Java Black
From memory when I did mine, a tapered punch was enough for me to lever the chassis/panhard bush hole over enough in order to line the holes back up, maybe with a small extension on it, but I don't remember it being that difficult, did mine with wheels on the ground not jacked up.
Post #1071011 8th Jul 2025 12:12am
paul 123
United Kingdom 1995 Defender 90 300 Tdi HT Auto Rutland Red
turn the steering with the wheels on the ground and i will align it
Post #1071038 8th Jul 2025 8:12pm
tommobot
Litterally just did exactly this...
Fitted an bolted the inner (higher) side, then jacked up this side under the axle and the other side lined up eventually and bolt slid through..
Post #1071067 9th Jul 2025 9:34am
CJs110
Put back on its own weight and used the steering. JOB DONE!
Thanks everyone for the insight. I followed as mentioned put the vehicle back on its own weight wheels on the ground.
Didn't have a second person to push the wing with, so used the steering method - rocked wheel back and forth, went under checked if it was aligned (repeated a few times lol) but eventually it lined back up!!
Watching the body shift over while the wheels stay put is a very odd sensation - but it really show just how much the axle had shifted!!
Thanks again all
Post #1071115 9th Jul 2025 3:56pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Use a ratchet strap of you are alone. Simplest way.
Good luck 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #1071238 11th Jul 2025 2:00pm
Procta
Yeah my dad did this with a strap, so that i could get the bolt in. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #1071274 11th Jul 2025 11:57pm
